Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 03-03-2011, 03:25 PM   #1
double pane windows
I had about 10 new milgard windows replaced with Vinyl. This morning I saw condensation on the outside of the window that had a pattern about 2 inches from the border of the window all the way around. It only appeared on 4 of the new vinyl windows. The condensation went away as the temp warmed up. Is this normal. It was not on the inside of the window nor the inside of the dual paynes
bobbroadley is offline   Reply With Quote
Old 03-05-2011, 07:34 AM   #2
double pane windows
Nothing to worry about if it is on the outside. Between the glass panes is a problem that indicates the seal between the panes has failed and either the glass unit or the sash will have to be replaced(depends on manufacturer). Condensation on the inside often indicates too high interior humidity.
Old 03-05-2011, 11:29 AM   #3
double pane windows
Thanks That is what I was trying to tell my wife but of course my opinion doesn't count yours does thanks again
Old 03-05-2011, 11:31 AM   #4
Experienced
Jackofall1's Avatar
double pane windows
Welcome Bob, to the best darn DIY"r site on the web.
Condensation on the outside is not a problem, anywhere else, they need attention.
Mark
Old 03-05-2011, 11:36 AM   #5
double pane windows
condensation on double pane windows netminder HVAC 18 01-06-2013 08:18 PM
Extreme condensation on single pane windows ikessky General Discussion 2 01-24-2011 03:31 PM
Double pane, Low E, Argon filled Windows ChristopherSprks General Discussion 5 01-24-2011 12:10 PM
narrow frame dual pane windows tns1 Building & Construction 0 12-21-2010 03:05 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
