Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 01-19-2013, 07:33 PM   #1
double pane windows
have old home with iron casement windows with single pane glass otherwise in pretty good shape-need to replace couple hundred panes with double pane-are they available in small sizes as 8x10 and is this feasible?
nopro is offline   Reply With Quote
Old 01-19-2013, 09:41 PM   #2
double pane windows
Not a great way to do it, even with the double pane glass you still have steel frames that are transfuring heat and cold right into the room.
Got any pictures inside and out?
Old 01-20-2013, 07:04 AM   #3
Windows & Remodeling
HomeSealed's Avatar
double pane windows
Probably not possible, and as joe mentioned, probably not advisable even if it was. Get some good interior storms (since they are casement units) if you want to improve your efficiency without replacement... Pics would definitely help to confirm recommendations...
HomeSealed is offline   Reply With Quote
Window Blinds for Double Hung Windows (2") 7 VII 7 Interior Decorating 7 01-16-2013 07:17 PM
Double windows lonerinalaska Windows and Doors 3 08-16-2012 05:32 PM
double pane windows trw43 Windows and Doors 2 12-30-2011 08:15 AM
sweating double pane windows etch Windows and Doors 6 10-31-2011 10:30 PM
Double pane, Low E, Argon filled Windows ChristopherSprks General Discussion 5 01-24-2011 12:10 PM
