Double Pane Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-20-2012, 10:25 PM   #1
jde
Double pane windows
Is it possible for a double pane window to shatter if the seal breaks? This happened to us about 2:30am. No extreme weather changes. No visible sign of damage on outside pane; however inside pane shattered. Not sure if we should suspect vandalism.
jde is offline   Reply With Quote
Old 06-21-2012, 12:08 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
jde, Welcome to the Forum
Originally Posted by jde View Post
........Not sure if we should suspect vandalism.
extremely unlikely, double pane windows are much harder to break than single pane.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-21-2012, 12:56 AM   #3
Rewards Points: 2,210
The inside shattered but the outside was fine? Seems like probably not vandalism
mae-ling is offline   Reply With Quote
Old 06-21-2012, 09:43 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Do you notice any bowing or distortion of the glass prior to this?... So it shattered not cracked? Definitely does not sound like vandalism if the outer pane shows no damage.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 06-22-2012, 07:44 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,134
Inner pane is probably as a result of a defect, thermal shock, etc.
That or a cat with a sore forehead and some slightly scared birds.
Old 06-22-2012, 08:28 AM   #6
the Musigician
DangerMouse's Avatar
Good one.
DM
Old 06-22-2012, 05:07 PM   #7
Rewards Points: 109
+1
agreed!
There are a number of reasons that your interior lite could break. Seal failure would not be one of those causes, however was there a reason to suspect that your window had seal failure?
Also, you used the word "shattered". Was the glass tempered - meaning did it shatter into all sorts of pebble size bits?
And, like HomeSealed asked, did you notice any bowing or distortion in the glass prior to it breaking? If you have other windows of similar size/shape take a look for distortion or bowing in the glass. Use a straight edge across the glass if there appears to be a problem.
How big are these windows and what style (double hung, casement, "crank-out", etc)?
oberon is offline   Reply With Quote
double pane windows trw43 Windows and Doors 2 12-30-2011 08:15 AM
sweating double pane windows etch Windows and Doors 6 10-31-2011 10:30 PM
Refilling Argon thermal pane windows Chiurato Windows and Doors 5 03-31-2011 08:25 AM
Double pane, Low E, Argon filled Windows ChristopherSprks General DIY Discussions 5 01-24-2011 12:10 PM
how to clean double pain windows DIYER33 General DIY Discussions 3 04-12-2005 12:53 PM
