Double Pane Vinyl Window Falls Down. - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 11:33 AM   #1
Double pane vinyl window falls down.
Window is 12 years old, that rod has fallen off a couple of times over the winter, lucky that it didn't crack the window when it slammed down, although it did scare my neighbors once. I figure to hire a window repair guy for this is going to cost me up to $150.00, none of the other windows in the house
has this problem.
Last edited by pinecone12; 05-25-2011 at 11:36 AM. Reason: trying to add text to my post
pinecone12 is offline   Reply With Quote
Old 05-25-2011, 09:47 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
At a $150 for repair, you'd be better off replacing the whole unit.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 05-26-2011, 07:52 AM   #3
kwikfishron's Avatar
Rewards Points: 196
You probably just need the sash spring/cord reattached or replaced. Any general handyman should be able fix it in short order.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
HomeSealed (05-26-2011)
Anyone ever seen two windows not double pane? FixitDragon Windows and Doors 3 04-21-2011 05:58 PM
double glass window pane problem- noquacks General DIY Discussions 3 01-31-2011 07:52 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Thermal Barrier Windows vs Vinal Windows MeraleeCrowl Remodeling 6 11-05-2008 05:46 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
