Double Hung Window Doesn't Stay Open - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-16-2013, 02:46 PM   #1
Rewards Points: 1,062
double hung window doesn't stay open
Can anyone tell why this not-so-old double hung window won't stay lifted open but just slides right back down? The side rails don't even offer any resistance, it just free falls as it is heavy. What can I do to fix it?
Old 06-16-2013, 07:15 PM   #2
Davejss's Avatar
Rewards Points: 772
The balances are either broken or disconected. Lift the sash about half way up, release the tilt levers, tilt the sash in, and take a look at the balance mechanism. It will either be a spiral spring or a string/cable system. Which ever style, it is most likely no longer properly attatched to the sash.
Davejss is offline   Reply With Quote
Old 06-17-2013, 06:53 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,780
I am going to guess a spiral balance in this case.
If that is the case, the balance is snapped internally or needs a couple of more twists on the coil.
Old 06-17-2013, 07:16 AM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+2. Spiral balance, busted or disconnected. You can order new ones if necessary.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 06-17-2013, 01:12 PM   #5
747
registered
747's Avatar
Rewards Points: 534
Go buy a little piece of doll rod and cut it. I have the same problem with a double hung. This solved it. Open window stick doll rode inside on rght. Problem solved.
747 is offline   Reply With Quote
Making a stationary window out of double hung jlewis Windows and Doors 6 03-04-2013 11:26 AM
What is a window that may not open? Toller HVAC 6 01-31-2013 09:53 AM
Looking for open faced window well cover. eabaker Windows and Doors 1 06-21-2011 06:40 AM
Installing twin double hung in 2nd story luvdairish Remodeling 7 07-22-2010 10:06 AM
Cannot lock Single Hung Gerkin Window ArchieT Building & Construction 13 07-02-2009 08:24 AM
