-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   double hung window doesn't stay open (http://www.diychatroom.com/f104/double-hung-window-doesnt-stay-open-181940/)
amakarevic 06-16-2013 02:46 PM
2 Attachment(s)
Can anyone tell why this not-so-old double hung window won't stay lifted open but just slides right back down? The side rails don't even offer any resistance, it just free falls as it is heavy. What can I do to fix it?
Attachment 72772
Attachment 72773
Davejss 06-16-2013 07:15 PM
The balances are either broken or disconected. Lift the sash about half way up, release the tilt levers, tilt the sash in, and take a look at the balance mechanism. It will either be a spiral spring or a string/cable system. Which ever style, it is most likely no longer properly attatched to the sash.
Windows on Wash 06-17-2013 06:53 AM
I am going to guess a spiral balance in this case.
If that is the case, the balance is snapped internally or needs a couple of more twists on the coil.
HomeSealed 06-17-2013 07:16 AM
+2. Spiral balance, busted or disconnected. You can order new ones if necessary.
747 06-17-2013 01:12 PM
Go buy a little piece of doll rod and cut it. I have the same problem with a double hung. This solved it. Open window stick doll rode inside on rght. Problem solved.
