Double Hung Tilt Vinyl Window - What Is Broken And Who Can Fix It? - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-06-2014, 09:54 PM   #16
Rewards Points: 484
A POSSIBILITY is as follows. Flat blade screwdriver, stick it in that slot, hold it HARD and turn it a bit. Brake should release and you can slide that stop up a bit and then turn it back to reset the brake. Same on the other side.then set that window again and give it a whack downward with your hand before tilting it in. Sometimes, that bottom piece gets of close to the bottom for everything to engage properly.
Ron
ront02769 is online now   Reply With Quote
The Following User Says Thank You to ront02769 For This Useful Post:
gregzoll (06-06-2014)
Old 06-06-2014, 10:22 PM   #17
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,258
May not work here though because the shoe is busted up a bit.
I am sure he can get it unlocked but whether the pivot pin will engage the show is another question.
Old 06-07-2014, 05:56 AM   #18
Rewards Points: 484
That being why the word possibility was in all caps. That said, that slot needs to be almost straight up and down for the thing to engage properly.....and it isn't. Worth a shot. Oddly enough just used that trick on 4 separate windows in a Habitat house I'm working on and had success but ALSO suggested that it might be best if the windows weren't tilted out anymore! Ron
Old 06-07-2014, 08:57 AM   #19
The parts should not be that hard to locate. Blaine Hardware has some obscure stuff and I have sent clients to them to repair a bunch of stuff and they are great.
