Door For Wine Cellar - Sealed, Insulated And Low Ceiling - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 07:24 PM   #1
Rewards Points: 159
Door for wine cellar - sealed, insulated and low ceiling
I am building a wine cellar in the corner of my basement.
This will have 2 walls against the cement walls.
The other 2 walls will be built and insulated to keep the heat from the rest of the basement out of the cellar.
I looked at entry garage doors at the store.
They are sealed and I am guessing insulated.
But they require a rough opening of 82" for a 80" door.
The max height I have is 78" for the rough opening.
Any comments on the type of door I should be looking for?
Would I need to custom order the door to size? Or buy something that I could cut down?
theedudenator is offline   Reply With Quote
Old 01-16-2012, 07:39 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,250
Order a custom door.
They are not that much more expensive in most cases and messing with the door is more trouble than it is worth.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
HomeSealed (01-16-2012), Tom Struble (01-16-2012)
Old 01-17-2012, 06:22 AM   #3
Yep, insulated flat panel or even raised panel prehung doors are available in any size from a local lumber yard. Big box is not a lumberyard.
Old 01-20-2012, 06:10 PM   #4
Rewards Points: 159
I wish I had a lumber yard in my area.
We have nothing but Lowes/Menards/Home Depot
Old 01-21-2012, 06:22 AM   #5
You can get custom doors thru them, but they would be my last choice.
Old 01-21-2012, 10:15 AM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I'm pretty sure that you do, they just don't promote themselves on a retail basis as their primary clientele is contractors. I'm sure that you can find someone close to you in the links below:
http://www.abcsupply.com/branch/results/state/DE
http://www.alliedbuilding.com/about/alliedbranches.aspx
http://www.google.com/search?sourcei...upply+delaware
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 01-21-2012, 11:53 AM   #7
Rewards Points: 2,240
Over the last two years - had to have two custom doors built.
The end result was fine.
However, we had to be careful dealing with the person that was ordering them.
The level of knowledge and expertise, at the "service desk", can vary!
Check what the "server-person" is ordering, before you have them order it!
rossfingal
(Yeah, they were from a "Big-Box", store!)
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
mae-ling (01-21-2012)
