Door & Window Replacement Question - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-13-2011, 10:09 PM   #16
Rewards Points: 5,336
We really need to simplify this. Too many words, not enough pertinient info.
Size of the rough opening(with the wood and such):
Wall to wall _____________
Floor to top _____________
Size of the door:
Width(not including the brick mold) _______________
Height(not including the brickmold ______________
Thickness of each side projection ________________
Thickness of the top projection ___________________
This way we see what you have and what you need.
Ron
B. Franklin 1759
Old 09-14-2011, 06:26 AM   #17
Rewards Points: 150
Pre hung door frame size --> 31.5" wide, 70.5" high. Door itself is a 30" door.
Ruff opening, without wood, ie the cement hole --> 33 1/2" wide by 72" high
Ruff opening with the wood --> about 30" wide, and about 69 1/2 - 70" high
Thickness of the projection (Im assuming by projection your referring to the cement sticking out??) -- 2"
Let me know if you need more info.
sbmfj is offline   Reply With Quote
Old 09-14-2011, 07:22 AM   #18
Remove the top bump so the height is ample for the door.
Remove the wood from both sides.
-If you can install thinner wood, say 1/2" ply, the rough opening will be 32 1/2".
-put tar paper between the concrete and the wood.
If the opening is too narrow to install the door with the brick mold on the door, remove it. Install the door and rip the brick mold to fit.
Ron
B. Franklin 1759
Old 09-14-2011, 08:24 AM   #19
kwikfishron's Avatar
Rewards Points: 818
Size of the door:
I like your new fill in the blank question form.
It even works (this time).
kwikfishron is online now   Reply With Quote
Old 09-14-2011, 08:43 AM   #20
Rewards Points: 150
so basically remove the concrete that in the way, right? If that chunk of concrete wasnt there, it wouldnt be an issue, so I agree.
Any tips on cutting that relatively big chunk of concrete? Reciprocating saw and a few good blades? Grinder with a cement disk, make cuts, and then chisel them out?
Thanks for your help guys!!
Old 09-14-2011, 09:20 AM   #21
Rewards Points: 121
Just throwing this out as food for thought. Completely remove the old door and all the wood framing - build a new wall on one side of the concrete opening and frame for the new door and just forget about trying to fit the new door into the old concrete opening.
jrepp44 is offline   Reply With Quote
Old 09-14-2011, 09:33 AM   #22
Rewards Points: 150
Thanks, but I think Id have a hard time trying to hang the door from scratch...I did think about it though...
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
