Door Threshold Repair - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-02-2013, 06:06 PM   #1
Rewards Points: 4,796
Door threshold repair
Have a typical exterior door threshold that looks like this.
http://www.alder-doors.com/media/wys...hreshold_1.jpg
I only want to replace the wood strip that is screwed on there, without taking the whole threshold out. The problem is, those screws are locked solid. I put some WD40 on the screw heads and let it soak, but I really don't think it's penetrating down to the level it needs to.
I have pried off that back piece of trim, and can cut through the screws through that slot if necessary, with a metal sawzall blade, but normally those screws go into tapped metal holes, and I won't be able to replace the strip with a new one and screw it back in.
Any ideas?
jeffnc is offline   Reply With Quote
Old 09-03-2013, 10:14 AM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
use an easy out/ bolt extractor... You can also get some PB blaster in there and it will work better than wd40. Both can be found at a hardware or auto store.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The repair is "The Bomb" tenzo HVAC 3 06-27-2013 10:04 AM
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 06:42 AM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 12:42 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
