Door Threshold Not Wide Enough - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-22-2013, 08:51 AM   #1
Rewards Points: 338
Door threshold not wide enough
My existing frame around the outside door threshold was rotting, and the threshold was this cheap plastic which was breaking up in the winter, so I decided to replace it.
I was shocked when I pulled it all out and went to place down the new threshold, that there is about an inch on either side of space. I remeasured the door, and this door is 37 1/4 inched wide! Whoever heard of such a thing??!!
What's the best way to handle this? I am afraid if I simply cut in chunks of wood:
a) it will look lousy as already it's very obvious that the aluminum is narrower than the door opening
b) water will infiltrate
I'll take any ideas gratefully!
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 07-22-2013, 09:01 AM   #2
kwikfishron's Avatar
Rewards Points: 92
Go buy a threshold for a 42" door and cut it down, or make your own.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
gregzoll (07-22-2013)
Old 07-22-2013, 09:28 AM   #3
Rewards Points: 6,652
Custom order door. Did you measure the frame to get the 37 1/4, or the actual door slab?
Old 07-22-2013, 10:24 AM   #4
Rewards Points: 12,886
Can you post a picture? Always helps to be able to see it like you can.
Old 07-22-2013, 12:12 PM   #5
Rewards Points: 338
The actual door, from edge to edge, is 37.25 inches. Yeah, it is def custom! Now I will see if the big box boys have 42 inch thresholds...
Old 07-22-2013, 12:24 PM   #6
Rewards Points: 92
If they don't just go to a lumber yard.
Old 07-22-2013, 12:43 PM   #7
Rewards Points: 338
Lowe's has the 42 inch ones, in Oak only. Big bucks, but looks like my only option! I should weather stain it or something to make it live longer, so I'll pick up some of that in my journey!
Thanks people.
Old 07-22-2013, 12:47 PM   #8
Rewards Points: 92
You should do something to it. What kinda depends on what you want it to look like.
Old 07-22-2013, 07:59 PM   #9
DIY staff
Rewards Points: 7,174
Red oak does not like water and will deteriorate quickly---
If you use red oak seal all sides and edges----I'd hold out for aluminum or hake one from white oat----
Hanging a chandelier on a 3.5" wide wood beam diyjames2786 Electrical 2 07-24-2012 08:07 AM
Double wide roof construction / ventilation issue cgrfish Building & Construction 5 05-30-2012 11:21 PM
Any way to put a 33" wide sink in a 38" wide hole? Natalie559 Plumbing 4 03-05-2012 08:02 PM
Multi rib metal roof on double wide...static vents wpilotm Roofing/Siding 0 09-10-2011 04:51 PM
engineered flooring-gap along last wall too wide golfgirl Flooring 5 12-17-2010 09:14 PM
