Door Threshold Height - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-10-2013, 11:59 AM   #1
Rewards Points: 202
Door threshold height
Hi all,
In a few weeks I will be installing an in-swing exterior patio door where a window currently is. My existing flooring is the original hardwood, which is attached directly to the floor joists (old house). I'm assuming eventually (who knows when) I will be redoing the floor and I'd rather not run into issues with the height of the door threshold on this door.
So, should I raise the door off of the existing floor? If so, what height and how? Just a piece of wood nailed or screwed to it? I'm thinking it should be raised 1 1/4" since if I redo the floors it will probably require 1/2" plywood and then 3/4" flooring. At the same time, I can't raise it too much because the direction of the door swing runs under a bulk head, which is already dangerously close to blocking the door from swinging all the way open.
Thoughts?
benleef is offline   Reply With Quote
Gas Fireplace Flame Height Control chh HVAC 3 09-09-2012 11:22 AM
What should be the height of wall? so roof pitch is 10 feet... vikasintl Roofing/Siding 2 07-04-2012 10:32 PM
ridge height calculation oxbow Building & Construction 19 01-14-2012 07:26 AM
How to frame new floor to match existing floor height taylor01 Carpentry 4 04-04-2010 08:59 PM
Code for basement ceiling height RDS Building & Construction 3 04-22-2008 10:46 AM
