Door For Storage Area - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-27-2013, 12:15 AM   #1
Door for storage area
Hi there,
I recently moved and in the finished basement the owners made a storage space under the stairs. The opening is 31 1/2 inches wide by 54 1/2 tall and they just have a curtain hung across on a flexible rod. I'm considering my options in making it look more finished and I came across these shutters and wondered if it would be possible to use them as doors? I haven't got ANY experience in this but thought I could first frame the doorway with wood as it is currently just drywall all around (doorway is about 4 inches deep). Then using swing hinges hang these shutters and put some sort of handle on each as well. Question is.....would this work outside of my imagination? Or does anyone have any better ideas? Thanks to any and all who could give me some advice . Here are the shutters: http://www.homedepot.com/buy/wood-co...l#.UQS1Ome4zVQ
Thx! Brenda
bren1519 is offline   Reply With Quote
Old 01-27-2013, 12:26 AM   #2
Rewards Points: 13,274
It would be better if you posted a picture of the area where you need the door.
Why would you use shutters and not just buy a bifolding door set for 1/2 the price?
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Is this your home or are you renting?
To meet code if this area is open or used for storage it has to have 5/8 sheetrock on the underside of the stairs.
Most of the time I frame in a knee wall at the back of the area since it's usless for storage.
Old 01-27-2013, 04:07 AM   #3
747
registered
747's Avatar
Rewards Points: 534
Post a pic so i can visualize
747 is offline   Reply With Quote
Old 01-27-2013, 04:07 AM   #4
747
registered
747's Avatar
Rewards Points: 534
Ps. those shutters are expensive.
Old 01-27-2013, 08:17 AM   #5
Ok...pics are attached.
Also...I looked everywhere for a door and I cannot see any with those dimensions. I've seen threads on cutting doors to size and for a non-carpenter type it just seemed way too complicated for me to do myself. Thanks again.
P.S. Not sure about the code here in Canada but I will check on that as well. Thank you for the info.
Door for storage area-20130127_080804.jpg   Door for storage area-20130127_080832.jpg
Old 01-27-2013, 09:20 AM   #6
Best way would be to just reframe the opening so a stock set of doors will fit.
Old 01-27-2013, 09:30 AM   #7
Probably not feasible given the size of the wall under the stairs. I think they made it as tall as they could. But thx
Backyard Play Area for Kids sippinjoes Landscaping & Lawn Care 8 06-30-2011 10:29 AM
Bouncy area under new shingles armanda Roofing/Siding 5 06-29-2011 09:59 PM
area surrounding top of shower stall mustangsalee613 Kitchen & Bath Remodeling 1 03-20-2011 11:08 PM
What to install first: 8x8 post OR paver area cgilbert Landscaping & Lawn Care 1 03-18-2011 07:21 PM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
