Door Sticks - Windows and Doors - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-25-2012, 09:58 AM   #31
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 898
Originally Posted by Tom Struble View Post
i'll buy that
HomeSealed gets one right from time to time.....
The Following User Says Thank You to Windows on Wash For This Useful Post:
Tom Struble (02-25-2012)
Old 02-25-2012, 11:24 AM   #32
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Originally Posted by HomeSealed View Post
getting all three sides level and plumb is key. If at that point the door is still hanging out of whack, then you start worrying about manipulation of the hinges, etc.
That should be the case in a perfect world but this isn't one, how many doors have you hung that were not square, I am talking about the door itself. Another thing to look at is if it is an old house how many times has the door been cut and by whom, how many times has the door been planed.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 02-25-2012, 11:40 AM   #33
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Actually when the jambs are plumb and level, I've rarely seen issues. That was my point though,is that you should start there.
You're other points are fine as well, but if you look at the pic, the door looks relatively new. In addition, those corner blocks being used on the casing are pretty common for a diyer that has no clue how to miter trim, and I'd imagine that lack of skill extended to the door install as well. This is all speculation on my part of course, but it is a common occurrence in my experience. I'd venture to say that 8 out of 10 doors that have issues and were installed at least somewhat recently are installation issues.
...and thanks for that WoW, no seriously, thanks.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
BigJim (02-25-2012)
Old 02-28-2012, 11:31 PM   #34
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Didn't check for plumb but the door on the hinge side is very tight below the bottom and above the top hinge. There is a larger gap maybe 1/4" on both sides of center hinge. The clearance on the other side is so great the latch is barely keeping door closed. I'm sure I could amuse everyone by showing the casings a friend of the pervious owner made. I guess based on their circumstances it had to do. There are no door casings on the doors on the second floor. At first I thought they were taken in foreclosure but there are no nail holes.
Will need to re-hang.
--Chris
Sent using Android DIY Chatroom
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
The Following User Says Thank You to ChrisDIY For This Useful Post:
HomeSealed (02-29-2012)
Old 02-28-2012, 11:56 PM   #35
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
You can bend your hinges out to close the gap on the striker side or you can shim behind the hinges to do the same thing.
Jim
