Door Sticks - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-19-2012, 09:24 PM   #1
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Door sticks
Hello,
This bedroom door only sticks during the winter. I am guessing it wasn't hung properly. Viewed from the inside the hinges are on the right and it binds at the top left. Where would I need to make adjustment? Do I need to re-hang the whole door?
Just thought I would ask just in case there is an easy way.
--Chris
Sent using Android DIY Chatroom
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 02-19-2012, 10:52 PM   #2
Ravenworks's Avatar
You may get away with adding a thin paper shim under the lower hinge,or you may need to trim it with a plane on the top. Either way it isn't going to take much.
Ravenworks is offline   Reply With Quote
Old 02-19-2012, 11:45 PM   #3
Rewards Points: 2,212
If I understand stand it is the knob side that hits at the top? if so then shim behind the top hinge, on the jamb not the door.
Hold up a book at see what happens when you sim out the top or bottom. Gives an idea of what to do.
If it binds for part of the year and not at other times. It means your house is shifting. Usually not a big deal. Any cracks in the walls?
mae-ling is offline   Reply With Quote
Old 02-20-2012, 02:49 AM   #4
Ravenworks's Avatar
Wrong,you do not shim the top hinge.
I would have to bet ,it is from humidity.
Old 02-20-2012, 05:28 AM   #5
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Pull one of the top hinge screws and replace with longer screw (2-1/2"). This will pull door away from jamb on the knob side.
titanoman is offline   Reply With Quote
Old 02-20-2012, 10:28 AM   #6
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Sorry it binds at the top left on the "top" of the door.
Yeah, I have another thread going about the humidity. This house is a headache...
--Chris the DIY Guy
Old 02-20-2012, 11:11 AM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 802
If the top of the door is dragging, you would shim the top hinge. You can also bend the top hinge by placing the thick end of a nail set in the hinge and closing the door slightly putting pressure on the door a little at a time until it bends the hinge enough. Be careful because it can pull the screws out of the jamb if not careful.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 02-20-2012, 01:59 PM   #8
Disabled wood vet
titanoman's Avatar
May make the upper side start dragging. Plane top of door?
Old 02-20-2012, 04:01 PM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 802
If it is too tight to the side jamb, you are right but if not it will fix it.
Jim
Old 02-20-2012, 04:28 PM   #10
Rewards Points: 512
give the top jamb a whack with a hammer and a piece of wood
princelake is offline   Reply With Quote
Old 02-20-2012, 07:12 PM   #11
retired union carpenter
Send a message via Yahoo to coupe
if the binding is on the jamb of the top? you can use an adjustable wrench, close it to just fit over hinge, bend it a bit back towards casing on top hinge. if it's binding on top of door/ header of jamb? do same on bottom hinge. or the thin cardboard strips placed off center on hinge side depending on way you need to shift door? cardboard strips= cereal box cardboard, 1/4"x length of hinge two strips top or bottom probably enough?
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
The Following User Says Thank You to coupe For This Useful Post:
Tom Struble (02-23-2012)
Old 02-21-2012, 06:04 AM   #12
Disabled wood vet
titanoman's Avatar
Creates separation gap in jamb.
The Following User Says Thank You to titanoman For This Useful Post:
Big Stud (02-23-2012)
Old 02-21-2012, 05:52 PM   #13
Rewards Points: 636
wow where to start ok if it is rubbing on the head of jam on knob side
1 before tweaking and shimming hinges when door is closed is there at least a 1/8 to 3/16 gap at top corner on latch jam.it can be less if you have a beveled door
2 do you have an 1/8 to 3/16 gap at bottom corner on hinge side
let me know because if not tweaking and shimming hinges will just make door rub else where
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 02-21-2012, 05:56 PM   #14
Rewards Points: 636
oh yea i do not just plumb it so happens i am a carpenter with repairing doors and installing doors for 10 years
Old 02-21-2012, 06:13 PM   #15
Disabled wood vet
titanoman's Avatar
Originally Posted by jaydevries
oh yea i do not just plumber it so happens i am a carpenter with repairing doors and installing doors for 10 years
Good to know where to go for door adjusting.
BigJim (02-21-2012)
