Originally Posted by Evstarr
I would not put an air tight glass door on a south facing entry with an old wood door. Particularly if it's a dark color.
Oh really? It does get *some* sun, which is blocked at times by the trees. Seems like we're getting conflicting opinions here.
Have you pulled interior trim off to insure that any voids are properly filled? A thick heavy solid wood door is not going to pass that much sound anyway. But an empty cavity around it will.
We've got an original door there. Having a mail slot in the middle of it is part of the problem. I don't think I'd feel comfortable removing the original decorative trim w/o damaging either trim or walls, or both. My soundproofing research does point out that voids around the trim could be a contributing factor. I might have to have somebody else look into doing that part for me.
If you think about it, an expanding bubble of hot air trapped by the storm has to go somewhere and in the summer, if it can't go outside, it's coming inside, increasing your ac load ( a little)
The living room is actually one of our coldest rooms so I we probably won't care if some of the heat is dispersed in there. Good point though, it has to go somewhere.
Thanks for your comments!
