Door Sealant Before Trim - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 04:04 PM   #1
Rewards Points: 1,062
door sealant before trim
I haven't installed trim on my entry door and was wondering if i should put Quad sealant between the jamb and the wall opening before installing trim or is it sufficient to only apply a bead around the trim once installed.
Old 07-14-2012, 04:11 PM   #2
Rewards Points: 13,752
Do both.
If it was mine I would not use Quad though on this one. Reason being your going to have a mess trying to clean it up off of the brick wall.
I'd use Alex 230 instead.
amakarevic (07-14-2012)
Old 07-14-2012, 05:03 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,784
Spray foam or backer rod and sealant the larger gaps.
You will make a mess trying to seal the larger gaps with sealant alone.
The Following User Says Thank You to Windows on Wash For This Useful Post:
mae-ling (07-14-2012)
Old 07-14-2012, 08:39 PM   #4
Are you saying Hilti foam or Great Stuff?
Old 07-14-2012, 09:54 PM   #5
Either or.
Any closed cell, window and door specific (i.e. low pressure) works great here.
Old 07-14-2012, 10:31 PM   #6
But only if there's room for it. Looks like somehow you ended up with tiny gaps. But your there and we only have a picture to go by.
Old 07-15-2012, 08:14 AM   #7
+1
That is why I said for the larger gaps. There may be more space between he framing and the door than is being shown between the brick and the door.
Old 07-15-2012, 08:21 AM   #8
I got ya, just did not want him to try and use the foam like it was caulking. I've seen DIY's do it before, gee that was fun trying to get it all off.
On customer had tryed to use it to stop a leak in a sink drain, now that was a sight. They had put the tapered sealing ring in backwards when the drain was installed.
Windows on Wash (07-15-2012)
Old 07-15-2012, 10:05 AM   #9
Tom Struble's Avatar
Rewards Points: 2,002
i use the needle tip on my foam gun for small gaps like that,less foam/ less expansion
Tom Struble is offline   Reply With Quote
Old 07-15-2012, 10:59 AM   #10
We have those tapered tips as well. You can get the foam into nearly any gap with those.
Tom Struble (07-15-2012)
Old 07-15-2012, 11:01 AM   #11
i should have said less foam less pressure
Old 07-17-2012, 06:04 PM   #12
Hilti foam gun does miracles in what a teeny bead it lets you apply. Like literally 1/8"
The Following User Says Thank You to amakarevic For This Useful Post:
Tom Struble (07-17-2012)
Old 07-17-2012, 06:21 PM   #13
but the needle tip lets you get the foam deeper in the crack instead of expanding out past the frame which after it hardens needs to be trimmed back sometimes falling out in the process
Old 07-17-2012, 06:27 PM   #14
like this
http://www.amazon.com/Todol-Foam-Gun.../dp/B004HEDSTK
Hardwood Flooring install around this trim? Cmudr1 Flooring 4 01-31-2013 10:29 PM
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 10:32 PM
New Roof but Fascia Trim Board Rotting ein0801 Roofing/Siding 6 07-15-2012 12:21 AM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 07:45 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
