Door Pro's .. Quick Question About Stops.. - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 08:07 PM   #1
Rewards Points: 149
Door pro's .. Quick question about stops..
Hello and thanks in advance. We had some solid core doors installed and all is well except the following:
2 of the doors have a little wiggle room to them so I would like to move the stops in tighter to the doors so when closed they do not rattle ..
The doors and jambs are primed only so they still need to be painted ...
Knowing all of this .. is there a trick or measurement I can use to get the stops tight and have the door shut with no rattle?
I would like to go right up to the door but worried that might be too tight after painting ..
Any thoughts are appreciated.
beachfront71 is offline   Reply With Quote
Old 03-12-2013, 08:15 PM   #2
Rewards Points: 13,274
Adjust the strike plate instead.
Look at the plate that the latch drops into as the door closes.
Better ones have a rectanguler hole in them where you can insert a flat screw driver to adjust them.
Of not then just remove and bend the little tab to make it close tighter.
http://www.bing.com/images/search?q=...ectedIndex=122
The Following 3 Users Say Thank You to joecaption For This Useful Post:
beachfront71 (03-12-2013), BigJim (03-12-2013), Windows on Wash (03-13-2013)
Old 03-12-2013, 08:22 PM   #3
Rewards Points: 149
Thanks Joe.
THat took all of 2 minutes and I am ssuming that also lets me readjust the strike plates at a later date after we paint .. if they are too tight then..
Check is in the mail.
Old 03-12-2013, 08:32 PM   #4
Send me a P/M and I'll give you the address, I need the money.
Quick question with cement board and underlayment supastar1568 Flooring 7 01-05-2012 06:03 AM
Quick Wire Size Question leeave96 Electrical 5 08-22-2011 06:33 PM
Quick outlet question RodBarney Electrical 5 08-20-2011 01:06 AM
New here! Quick question. tmichelsons Building & Construction 5 06-15-2011 01:18 AM
Quick Bathroom Plug and switch Question mclemenc Electrical 5 01-30-2011 11:02 PM
