Door Not Shutting All The Way - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 08:06 PM   #1
Door not shutting all the way
The door that goes into my garage will not latch closed. The latch that hits the sticker plate is too low to lock into the closed position. When I slam it close I can just pull back open without twisting handle. If I lift top of door up up it latches close. Any ideas on how I fix the issue and raise the door up since the hinges are in a recessed location on frame.
Donald-64 is offline   Reply With Quote
Old 12-15-2011, 08:13 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Remove one of the screws from the upper hinge that goes into the jamb and replace it with a 2 1/2" deck screw. When screwed in tight it should raise the door just enough.
If not, lower striker plate.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
Windows on Wash (12-15-2011)
Old 12-15-2011, 08:45 PM   #3
Rewards Points: 13,750
The longer screw idea may work in most cases but trying to move the latch plate would be a mistake. Moving it that small an amount and the screws will not grab because there to close to the other screws holes
Instead A few swipes with a Dremel tool with a grinding stone in the latch hole will let the bolt drop in the hole.
Old 12-15-2011, 08:50 PM   #4
Any ideas if I don't have any power tools?
Old 12-15-2011, 08:50 PM   #5
Disabled wood vet
titanoman's Avatar
Yes, without filling the screw holes with a putty and then drilling new screw holes, a little grinding on the plate would be better.
Old 12-15-2011, 08:53 PM   #6
You own a house and have no tools?
Time to go get some, ha it's Christmas go buy youself a gift.
TheDoorGuy (12-17-2011)
Old 12-15-2011, 09:00 PM   #7
I have a drill. Nk need for other types it's a new house
Old 12-15-2011, 09:04 PM   #8
Disabled wood vet
titanoman's Avatar
Do you have a Philips bit and a long screw? Try the first suggestion. Usually works.
Old 12-15-2011, 09:36 PM   #9
I do. I am going to try that first thing tomorrow. Thanks
AC shutting on and off... DonnieC HVAC 2 09-10-2011 04:47 AM
Furnace keeps shutting off enemydream HVAC 7 03-19-2011 04:29 PM
My gas furnace keeps shutting off. rj8931 HVAC 1 12-06-2010 06:57 PM
Burner Keeps shutting off seabo HVAC 3 01-05-2010 12:02 AM
5 Ton split system keeps shutting down mahjohn HVAC 1 06-10-2006 07:31 AM
