-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Door not shutting all the way (http://www.diychatroom.com/f104/door-not-shutting-all-way-126736/)
Donald-64 12-15-2011 08:06 PM
The door that goes into my garage will not latch closed. The latch that hits the sticker plate is too low to lock into the closed position. When I slam it close I can just pull back open without twisting handle. If I lift top of door up up it latches close. Any ideas on how I fix the issue and raise the door up since the hinges are in a recessed location on frame.
titanoman 12-15-2011 08:13 PM
Remove one of the screws from the upper hinge that goes into the jamb and replace it with a 2 1/2" deck screw. When screwed in tight it should raise the door just enough.
If not, lower striker plate.
Sent from a Samsung Galaxy S2
joecaption 12-15-2011 08:45 PM
The longer screw idea may work in most cases but trying to move the latch plate would be a mistake. Moving it that small an amount and the screws will not grab because there to close to the other screws holes
Instead A few swipes with a Dremel tool with a grinding stone in the latch hole will let the bolt drop in the hole.
Donald-64 12-15-2011 08:50 PM
Any ideas if I don't have any power tools?
titanoman 12-15-2011 08:50 PM
Yes, without filling the screw holes with a putty and then drilling new screw holes, a little grinding on the plate would be better.
joecaption 12-15-2011 08:53 PM
You own a house and have no tools?
Time to go get some, ha it's Christmas go buy youself a gift.
Donald-64 12-15-2011 09:00 PM
I have a drill. Nk need for other types it's a new house
titanoman 12-15-2011 09:04 PM
Do you have a Philips bit and a long screw? Try the first suggestion. Usually :)works.
Donald-64 12-15-2011 09:36 PM
I do. I am going to try that first thing tomorrow. Thanks
