Door Latch And Lock Doesn't Close Properly - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 01:16 PM   #1
door latch and lock doesn't close properly
My front door latch and lock used to have no problem closing. In the last few months it has become increasingly difficult to close the front door because the latch doesn't fit the hole, and neither does the lock. I have to lift the handle (and thus the whole door) up in order for the latch to fit.
Any suggestions on how to fix the problem?
Thanks.
grgryl is offline   Reply With Quote
Old 07-11-2011, 01:21 PM   #2
check the screws in the hinges first and make sure they are all tight. sometimes things have moved over time. most of the time this will take care of it or a 3 inch screw in the top hinge will pull the door back into position. worst case is the house settled on the hinge side. does the door look square in the opening or is the top edge of the door closer to the door jamb then it is at the bottom?
Old 07-11-2011, 01:33 PM   #3
One of the screws isn't tight, but when I tried to tighten it, found that the wood must be stripped because I could not tighten it. I suspect that the door frame has shifted and is not square because both the door handle latch and the deadbolt don't line up.
I'd rather not change the whole door because the house might shift again. Maybe it's the very hot weather that causes some shift?
Old 07-11-2011, 01:36 PM   #4
try a longer screw in the top hinge. did you tighten the screws in the door and the frame?
Old 07-17-2011, 01:07 AM   #5
Sounds like you need to make adjustments to the panel of the door. Depending on the brand, typically you should have about 1/4" play for adjustments in the hinges. This is to accomidate for setteling over the years. Also, be sure that there is a long screw ran in the center of the hinge. This can also cause a panel to sag. The door does not need to be replaced. Dips/humps in the head or sill of the frame can also cause a door to loose adjustment. This would be an installtion issue and can be determined with a level.
Windowgirl is offline   Reply With Quote
Old 07-17-2011, 01:47 AM   #6
Thanks, I ended up having to move the panels on the door frame. (See the attachments). The screw that was loose, was on the door handle panel (I misunderstood DannyT's post). The screws at the door hinge were tight, so I didn't make any adjustments.
Hopefully the door frame (or house) won't move again.
Thanks for the tips.
door latch and lock doesn't close properly-imag0210.jpg   door latch and lock doesn't close properly-imag0211.jpg
Old 07-25-2011, 10:30 PM   #7
Rewards Points: 5,336
I've never seen hinges like that. Do you have a picture of these adjustable hinges?
Ron
B. Franklin 1759
Old 07-25-2011, 10:56 PM   #8
here are some adjustable exterior hinges
http://www.adjustabledoorhinge.com/exterior-hinges.html
Lock Tab installation for Harbor Breeze Fan Andy B General DIY Discussions 0 02-06-2010 02:12 PM
Window doesn't close gsk3 Building & Construction 5 09-17-2009 10:21 AM
Cannot lock Single Hung Gerkin Window ArchieT Building & Construction 13 07-02-2009 09:24 AM
had to break down a door, how to repair splintered wood around lock area? mxyplizk Carpentry 17 06-09-2009 09:42 AM
Window Doesn't Close Properly Dave in Michigan General DIY Discussions 6 12-05-2007 09:25 AM
