Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 10-20-2011, 10:47 PM   #1
I'm Your Huckleberry
Door Knob With Hidden Screw
How do I remove it? I've twisted the inside door knob's faceplate off and I can see the screws that hold the inside and the outside door knobs together but how do I get the faceplate off so I can put a screwdriver to them?
I've been reading up on it but I'm not getting anywhere.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 10-21-2011, 01:53 AM   #2
you gotta take the knob off. theres sometimes a clip ring on it, allen screw, or there could be a cover on the end of the knob hiding a screw
Dwillems is offline   Reply With Quote
Old 10-21-2011, 07:13 AM   #3
Super Moderator
look for a slot in the knob--if you have one--push a screw driver blade into it to release the spring.
Old 10-21-2011, 06:32 PM   #4
I've looked but can't tell. Both you guys say the same thing that the articles do. Luckily I have channel locks and saw zawls. Ill get it off.
Thanks.
Old 10-21-2011, 06:37 PM   #5
Experienced
Jackofall1's Avatar
Post a pic Doc, that would be real helpful.
Mark
Old 10-21-2011, 07:34 PM   #6
Moderator
kwikfishron's Avatar
I once took a skill saw to a door knob that had me locked out, worked like a charm.
As mention though post a picture, you’re just missing something.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 10-21-2011, 07:39 PM   #7
Ill post some in a bit, thanks.
Old 10-21-2011, 08:45 PM   #8
Yup, Ill take pics as I demo.
Old 10-22-2011, 06:42 PM   #9
I haven't taken it off yet but here it is. I tried to get a pic of the inside but not much room for visibility.
And lunch just now.
Stuck Screw IceTreay General Discussion 11 09-09-2010 02:56 PM
Azek Decking and Cortex Screw System EdtheC Flooring 2 08-27-2010 08:48 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 03:17 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 11:47 PM
Sheared head on Tapcon screw - how to remove? mkuether Remodeling 9 12-04-2008 09:18 PM
