Door Jam - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-09-2013, 11:02 AM   #1
Rewards Points: 258
Door jam
Okay I am not sure if it's the door or the frame or both but something is warped. So I need some help deciding which and figuring out the best corse of action. All pictures are with the door fully closed. The door closes easy and does not bind.
Door jam-image-1204212216.jpg   Door jam-image-1765158226.jpg   Door jam-image-2168500534.jpg   Door jam-image-2298338344.jpg
redman88 is offline   Reply With Quote
Old 12-09-2013, 11:14 AM   #2
Jmayspaint's Avatar
Rewards Points: 536
Looks like the weather stripping is missing.
Jmayspaint is online now   Reply With Quote
Old 12-09-2013, 11:15 AM   #3
Rewards Points: 14,312
What is that chopped up mess on the side of the door?
So what's the issue? That wide gap?
Old 12-09-2013, 11:18 AM   #4
Rewards Points: 258
No the weather striping is still there. The chopped up mess it where the screen door was on the opposite side from where it was when I took it off
Old 12-09-2013, 11:43 AM   #5
Looks like someone try to use a cheap hollow core interior door and make it work as an exterior door.
Time for a new real exterior door.
Old 12-09-2013, 01:20 PM   #6
Rewards Points: 258
Yeah that what I am thinking
Old 12-09-2013, 04:10 PM   #7
AHH, SPANS!!!
Rewards Points: 1,166
you will get best results and be happier with a new door unit installed instead of sticking a new exterior slab on there
hand drive is offline   Reply With Quote
Old 12-09-2013, 06:02 PM   #8
Rewards Points: 258
Yep old house only going to do just slabs for interior doors
Old 12-09-2013, 08:03 PM   #9
Believe it or not it's faster and will come out better with prehung not just slabs.
Old 12-10-2013, 06:46 AM   #10
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
You will spend 2X as much time trying to get a slab to work right. Believe me.
The Following User Says Thank You to Windows on Wash For This Useful Post:
oh'mike (12-10-2013)
Old 12-10-2013, 07:08 AM   #11
DIY staff
Rewards Points: 7,174
Yep---Slabs take as long or longer to install as a prehung door. And a lot more tools.
Windows on Wash (12-10-2013)
Old 12-10-2013, 10:02 AM   #12
...and skill.
That is something you can find at HD or Lowes in a box either.
I know when I am over my head and I have done one and it took forever.
Won't ever attempt that again...trust me.
Old 12-10-2013, 10:11 AM   #13
AHH, SPANS!!!
if you do change out full units for interior doors plan to put back larger trim so it covers the boo boos from removing the old door and trim, you then only need to caulk new trim to wall...
The Following User Says Thank You to hand drive For This Useful Post:
Old 02-09-2014, 10:02 PM   #14
I hate slotted screws.
samlsn's Avatar
Also, the lines are going to show on the floor where the old jambs sat. I've even seen gaps in some cases when it's all finished. That's one of the downsides to pre-hungs vs. retro fit
samlsn is offline   Reply With Quote
The Following User Says Thank You to samlsn For This Useful Post:
oh'mike (02-10-2014)
