Door Hinge Spring Shim - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-28-2012, 11:12 AM   #1
16 years ago I moved into a new home that had a door that wouldn't stay in the open position. The builder had hung it a little out of plumb. Rather than fixing the plumb condition, the builder installed a spring steel shim between the hinge and door jamb (on the top and bottom hinges) that has 3 little plastic feet on it that rub on the barrel of the door side of the hinge. It has worked perfectly and silently for all of these years but is now starting to loose its effectiveness. The plastic feet are worn. Does anyone know where I could get these shims to replace the worn ones?
Marlowe306 is offline   Reply With Quote
Old 02-28-2012, 11:16 AM   #2
Rewards Points: 14,290
I've never seen one.
Remove one of the hinge pins and set it between two blocks of wood and tap it with a hammer to slightly bend it and reinstall always works for me and it's free.
Old 02-28-2012, 11:48 AM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
joe, I'm not sure I understand what you are saying... Are you suggestion to bend the hinge pin?
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 02-28-2012, 01:36 PM   #4
I have bent hinge pins to increase the friction in the hinge before but always end up with a squeaky hinge over time. These shims have been silent for 16 years. That is why I would like to find and replace them rather than bending the pin.
The Following User Says Thank You to Marlowe306 For This Useful Post:
HomeSealed (02-28-2012)
Old 02-28-2012, 03:03 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Thats what I was thinking Marlowe. Its not a terrible "quick fix", but it could have consequences as you mentioned.
www.HomeSealed.com
Garage Door Unbalanced - Adding Larger or Additional Spring? super20g Windows and Doors 24 05-29-2013 11:12 AM
Ever install a door spring on a 2 door? noquacks Automotive Repairs 19 09-17-2011 06:29 AM
proper way to shim 2x4 purlins aphilstrider Roofing/Siding 0 05-10-2011 08:08 AM
Size of Garage Door Torsion Spring planet Carpentry 3 12-19-2010 03:29 PM
Spring Hinges jb198606 General DIY Discussions 3 02-06-2006 08:40 PM
