Door To Garage From Inside - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-11-2012, 12:46 PM   #1
Door to garage from inside
Where to start? I know builder made pre frame. Is that meam I need to buy pre hung door?
kyungyun is offline   Reply With Quote
Old 09-11-2012, 12:52 PM   #2
If the door is framed out then you should be able to put a pre-hung door in. Measure the size of the opening from the inside of stud to stud. That will give you the rough opening dimensions and you can match that up at Home Depot or wherever you go to get the door.
When you do get the door pick up a pack or two of shims, you'll need them to get everything square when you are installing the door.
NHtransplant is offline   Reply With Quote
The Following User Says Thank You to NHtransplant For This Useful Post:
kyungyun (09-11-2012)
Old 09-11-2012, 01:06 PM   #3
DIY staff
Rewards Points: 7,174
If it is the door from the garage into the house --it must be a fire rated door---
Give us your location and someone here could look up the rating for your area--
Old 09-11-2012, 03:22 PM   #4
Rewards Points: 13,690
Post a picture of what's there now.
Is this new constrution?
Is the sheetrock up?
Old 09-11-2012, 06:14 PM   #5
I live in vaughan ont. canada
Old 09-11-2012, 06:58 PM   #6
DIY staff
Building Standards Department
This is your local code enforcement office--they have the codes in a PDF file --which I can't open with this computer---
A fellow Canadian may know the fire rating off the top of the head---so read--or wait---Mike----
Old 09-13-2012, 06:16 AM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,558
This must be an exterior door (i.e. air tight) application and must meet the burn time requirements.
The Following User Says Thank You to Windows on Wash For This Useful Post:
kyungyun (09-13-2012)
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 07:54 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Painting the inside side of Tar Paper; unfinished detached garage cityparkmark Building & Construction 8 03-03-2008 09:15 AM
