-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Door to garage from inside (http://www.diychatroom.com/f104/door-garage-inside-156525/)
kyungyun 09-11-2012 12:46 PM
Where to start? I know builder made pre frame. Is that meam I need to buy pre hung door?
NHtransplant 09-11-2012 12:52 PM
If the door is framed out then you should be able to put a pre-hung door in. Measure the size of the opening from the inside of stud to stud. That will give you the rough opening dimensions and you can match that up at Home Depot or wherever you go to get the door.
When you do get the door pick up a pack or two of shims, you'll need them to get everything square when you are installing the door.
oh'mike 09-11-2012 01:06 PM
If it is the door from the garage into the house --it must be a fire rated door---
Give us your location and someone here could look up the rating for your area--
joecaption 09-11-2012 03:22 PM
Post a picture of what's there now.
Is this new constrution?
Is the sheetrock up?
kyungyun 09-11-2012 06:14 PM
I live in vaughan ont. canada
oh'mike 09-11-2012 06:58 PM
Building Standards Department
This is your local code enforcement office--they have the codes in a PDF file --which I can't open with this computer---
A fellow Canadian may know the fire rating off the top of the head---so read--or wait---Mike----
Windows on Wash 09-13-2012 06:16 AM
+1
This must be an exterior door (i.e. air tight) application and must meet the burn time requirements.
