Door Gap - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-03-2011, 01:36 PM   #1
Door Gap
There is a gap between the top of my door and the weather stripping. As you can see in the second picture the inside door trim is above the door height. How should I fix it? The upper door frame is level. The door itself is a little off but not as much as the gap.
travisvadon is offline   Reply With Quote
Old 03-03-2011, 01:52 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 710
The door is clearly sagging pretty bad. First make sure that the hinge screws are tight. If they are, then you'll need to pop the door off and shim the hinges properly. (adding to the lower hinge will kick that top corner up)
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 03-05-2011, 07:39 AM   #3
Remove the two inside screws(usually 3/4 or 1" screws) in the top jamb hinge. Install 3" deck or #12 screws going into the house framing. Tighten with a drill driver or similar to pull the door in. This should fix or greatly improve the gap.
Old 03-05-2011, 08:57 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
X2
I like to use GRK screws for this application.
They require a Torx or star bit.
They are great because they will NOT slip like a phillips head
tcleve4911 is offline   Reply With Quote
Old 03-05-2011, 10:33 AM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Travis, Welcome to the Forum
Originally Posted by HomeSealed View Post
The door is clearly sagging pretty bad.....
I would not call this a door sag but more likely a structural problem that has caused undo settling on the hinge jamb. This may have occurred over a long time as the trim identifies this as an older house.
The two red reference lines I put on Travis's pic are equally spaced so I would not call this a door sag.The advice given on new screws is still valid because the door will have to be rehung. It will also mean lowering the latch strike plate.
The gap at the top of the door will now move to the door bottom. If the floor is just hardwood the gap may be covered with a door sweep.
Disclaimer
& Stay Safe
.....Bob Lavery
