Door Frame And Rough Opening Same Size - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-18-2011, 05:42 PM   #1
Exclamation
Door Frame and Rough Opening same size
I ordered a interior pre hung door from my home improvement supply and I gave them the size of the rough opening. The top has about an inch of space but the width on the sides near the top is the same size width of the rough opening and the bottom of the frame on the sides has about a quarter of an inch gap on each side. I trimmed the rough opening so that the door will just fit. In this scenario can this door be squared and leveled?
surferguy01 is offline   Reply With Quote
Old 03-18-2011, 07:47 PM   #2
Registered User
Rewards Points: 5,236
Sounds like they gave you the closest width size for standard. If the jambs are perfectly plumb, it will work. If not plumb....... The top gets covered by trim. Usually 2" wider on the door width, 2/4 =30", 2/6 =32", etc. This gives you room to shim for plumb.
AND, welcome to the forum!
Gary
Old 03-19-2011, 08:56 PM   #3
Rewards Points: 1,448
The top part of the door unit will fit snugly in the framing rough opening. If you are lucky you will be able to adjust the bottom part of the door unit, specifically the ends of the door jambs, within the 1/4 inch clearance and still get it square.
Odd sized existing rough opening in interior door. t_mott85 Remodeling 2 11-24-2010 12:56 PM
Replacement Windows Smaller Than Rough Opening stubits Remodeling 1 08-25-2010 07:19 AM
New rough opening to basement - spiral staircase benjamincall Building & Construction 8 07-16-2010 06:53 PM
exterior door frame size and rough opening kevincw01 Building & Construction 3 06-06-2010 09:26 AM
rough opening for glass block oxicottin Remodeling 5 05-04-2008 09:01 PM
