Door Draft Stopper - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-23-2013, 09:10 PM   #1
Rewards Points: 208
Door Draft Stopper
what would you use for a door draft stopper for a bedroom door?
i've seen these cheap tubes in stores, but don't think they work.
http://www.amazon.com/Twin-Draft-Gua...+draft+stopper
Scully is offline   Reply With Quote
Old 11-23-2013, 09:14 PM   #2
Rewards Points: 14,026
What type heat do you have?
The reason I ask is if it's forced air there needs to be a gap under the door for return air flow.
Old 11-23-2013, 09:39 PM   #3
Rewards Points: 208
it's forced air. i have cold air return vents on the wall next to the floor and the heat vents are higher up. house built in 50's.
Old 11-23-2013, 09:48 PM   #4
Is the reason you need this is because the room is going to be unheated and your trying to close it off?
Old 11-23-2013, 09:50 PM   #5
Rewards Points: 208
i also use a space heater, so i just want it warmer in the room.
Old 11-24-2013, 09:14 AM   #6
Rewards Points: 236
those do work. but only on a hard floor. carpet, not so much. or if the gap is tall.
Fix'n it is offline   Reply With Quote
Old 11-24-2013, 09:37 AM   #7
Add a door sweep.
Raise the drain stopper? Eagle One Plumbing 11 11-14-2013 12:28 PM
Bathroom sink. Drain pipe cracked from stopper lever. Mathlete Plumbing 11 11-10-2012 02:34 PM
Tub drain leaks when stopper pulled majenngs Plumbing 4 07-19-2011 12:06 PM
Sink Drain Stopper Won't Pop Up erclark Plumbing 7 07-11-2009 07:31 AM
