Does A Bi-Level Home Need An Egress Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-18-2013, 12:06 AM   #1
Does A Bi-Level home need an Egress window
This might be a dumb question. Was wondering if a Bi level home needs an Egress window. The window sits just a little bit above ground level.
jclee is offline   Reply With Quote
Old 06-18-2013, 12:17 AM   #2
Rewards Points: 940
It doesn't matter which level of the house, or the color of the paint. You have to be able to enter/exit the room to/from the exterior.
cleveman is offline   Reply With Quote
Old 06-18-2013, 12:19 AM   #3
So it just needs to meet the opening requirements and the 44 max height from floor, correct?
Old 06-18-2013, 06:29 AM   #4
DIY staff
Rewards Points: 7,174
Yes,that is correct----
Old 06-18-2013, 07:06 AM   #5
Not so new
12penny's Avatar
Rewards Points: 520
At ground level, 5sf net clear opening, minimum height 24" and minimum width 20".
Those windows IMHO dont meet egress requirements.
12penny is offline   Reply With Quote
Old 06-18-2013, 07:50 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
5.7 sq/ft to be exact.
You are correct that those windows do not current meet egress.
Old 06-18-2013, 07:57 AM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 710
+1 to all of the above. Change that window to a slider or twin casement and you should be in business.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 06-18-2013, 07:58 AM   #8
Not so new
12penny's Avatar
Rewards Points: 520
Could very well be. I was under the impression it was 5sf for ground level windows and 5.7sf for everything above that. Might be 2006 code I was thinking. Hard to keep it all straight.
Old 06-18-2013, 09:07 AM   #9
Yes. That's what I had in mind. Thanks
Egress Window Recommendations jhakkim Building & Construction 4 03-08-2012 10:05 AM
Egress Window Header? ottoguy Building & Construction 3 09-08-2011 11:22 PM
egress window kikipauw Building & Construction 3 11-10-2010 07:30 AM
egress window wall saturn78 Building & Construction 2 05-10-2010 06:27 AM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 04:47 PM
