Do They Make Privacy Locks For Double Mr & Mrs Doors? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-14-2012, 08:49 AM   #1
crankcase's Avatar
Do they make privacy locks for double Mr & Mrs Doors?
I am looking to install a Mr & Mrs double door set (both doors active) for a bedroom / futrure excercise room. More than likely hollow core. I would prefer to go with a standard knob style rather than a multi point tirm. What options do I have for a privacy lock if any? The only thing that I could think of is an internal rod or two that catch in the top of jam and/or floor but I have only seen this on commercial doors. Maybe my best option is a few ball catches and a do not disturb sign.
crankcase is offline   Reply With Quote
Old 08-14-2012, 12:06 PM   #2
Rewards Points: 14,026
Stock doors will come with ball detents one one side and only one bore side door.
If for some unknown reason you want to you could add a matching dummy knob on the other door. There just for looks and have no latch.
Old 08-14-2012, 12:15 PM   #3
Rewards Points: 1,010
There are ways to do it, but be prepared to spend a lot of money, and probably go to solid core. It can get complicated and rather ugly, especially if you get a system that requires a indexer. Best to find a good hardware specialty store, with a knowledgeable sales staff.
If a astrigal is not needed, life is a little simpler
Anti-wingnut is offline   Reply With Quote
Old 08-14-2012, 01:05 PM   #4
crankcase's Avatar
I was figuring without astrigal. Either a bulb gasket or brush to close the gap. It would almost seem like I would need a bore for the knob then a vertical bore through each door. Then mount the latch vertical with a really long bolt that would mate with the strike mounted in the top jam.
I just never dealt with a double door before and wasn't sure if hardware existed for such a situation.
Old 08-14-2012, 01:18 PM   #5
crankcase's Avatar
You know my last post got me thinking... How thick are the edge and top/bottoms of hollow core doors before they turn hollow?
Old 08-14-2012, 02:14 PM   #6
Less than 2" in my experience
Evstarr is offline   Reply With Quote
Old 08-14-2012, 04:50 PM   #7
43 years in construction
Arkitexas's Avatar
You need a cremone bolt with lever. Not very common these days. Do a web search.
http://www.signaturehardware.com/pro...FQZrtgodSC8ABg
http://www.baldwinhardware.com/Produ.../8105-030.aspx
Rick
Arkitexas is offline   Reply With Quote
pocket doors ...how to make fire rated clasact Building & Construction 21 03-11-2011 04:46 PM
Pre hung doors vs hanging doors myself Windows Remodeling 6 04-09-2010 02:20 PM
Do Floor Installers Usually NOT Trim Doors? thebigsee Flooring 20 11-22-2009 09:14 AM
Interior door swelling? jdeters79 Remodeling 9 08-15-2009 10:51 AM
Anyone know how to make cafe doors? versatile1 Carpentry 3 08-01-2008 09:39 PM
