-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   DIY'ing a curtain pole bracket (http://www.diychatroom.com/f104/diying-curtain-pole-bracket-158923/)
Ethnod 10-04-2012 07:01 AM
1 Attachment(s)
Could use some help and advice.
We just moved into a house and its drafty, very much so. We are working on some stuff to resolve this but one of the things we have done it to get some curtains, to block the drafts from the worst doors, but as I was about to put them up I realised that there is too much of a gap between the doorway and the curtain and that they would block some but not all of the draft.
So this got me thinking and I have a solution but I could use some help.
btw, its a bog standard wooden pole
http://www.hardwareireland.ie/js/tin...rtain_pole.jpg
I want to cut in half the part I am supposed to attach to the wall, by doing this I should close the gap between the door and the curtain and reduce the draft. However, they are connected by attaching a plate to the wall (this plate has a bolt coming out of it) and then screwing the wooden holder into that.
My problem is that, once I cut this holder in half, I lose the bit that I am supposed to screw onto the attachment that is now on the wall. I was looking for a replacement for that but issue is that 1 I cant find any and 2 I dont even know what the thing is called so I have to describe it every time.
The one I am talking about uses a system where into the wooden pole holder they have screwed in a large wooden screw that is hollow with bolt threading in this hollow section.
So I am hoping someone know the name of this thing I am looking for and also where I can get it.
Also, I am looking for another plate (with the bolt sticking out) that I screw into the wall and that I later fit the wooden pole bracket to.
Anyone know where I can find these?
Please see attached pic for an illustration. Might be easier than my description :)
joecaption 10-04-2012 07:14 AM
All that extra work instead of figuring out why the windows are leaking air and fixing that instead:eek:
How old is this house and is there still wooden framed windows with the old sash weights?
Ethnod 10-04-2012 07:27 AM
Makes me sad when I have to quote myself but anyways.
Before I get into it, the house is rented, no mine and as a result there is only so much I can do. As pointed out above, I am doing a tonne of other things and things have improved drastically.
No, the house was built in the 70's and we have PVC double glazed windows.
Not to be rude man but I did ask a specific question, if you can help please do so but criticizing me is not appreciated.
DannyT 10-04-2012 07:16 PM
look for hanger bolts. home depot has a few different sizes. you will need to drill a pilot hole in the piece so it doesn't split when you screw the hanger bolt in. possibly you could unscrew the one that is in there now and reuse it.
Ethnod 10-05-2012 06:09 AM
DannyT, you are a legend. Thank you so much. Now at least I know what I am looking for
