#1 |
Determining potential door height?
Hello all,
I'd like to install sliding glass doors where I currently have large windows. I found a great set for sale on craigslist, much nicer than I can usually afford, but am not sure how to tell whether they would fit in height - they are taller than my windows. The current windows end 11.5" off the ceiling, but maybe there's a support beam running across them below the ceiling. Do I need to tear out the wall to determine the max height they can be (i.e., where the support beam is)? Thanks! |
#2 |
It's called a header.
Most likly your going to have to open up the wall anyway to be able to redo the header. http://www.bing.com/images/search?q=...lectedIndex=25 |
#3 |
Yes. We'll probably tear most of the wall out in the process. But if I want these doors, I need to buy them now but I don't plan to do the job for quite a while (I have a lot of reading to do before I can do this job!) so am hoping for a non-destructive way to determine where support beams (headers?) need to be before buying mis-sized doors.
Thanks! Julie |
#4 |
Looks like it's the top plate I'm trying to determine the height to the bottom of since that would determine the maximum height of the doors. (or is a minimum header required below the top plate?)
Julie |
#5 |
Is this a load bearing wall?
#6 |
Yes, it is weight bearing, and I just read that that's why I need a header and that I can determine the width from the length needed.
#7 | |
DIY Enthusiast
Determining potential door height?Quote:
If so,its unlikely you can. Odds are you already have a header above the window,removing the window for a door which will be wider will require the header to be as wide as the door opening or wider to carry the weight of the opening. A header is usually made out of two 2x10 boards with half inch ply between then. |
#8 |
"Nail-Bender"
How wide are the existing windows? -
How wide is the door you want to put in? Are the existing windows, one unit? - or is there a space between them - several inches? A picture would help. rossfingal |
#9 |
Exterior Construction
+1
You might be very near the biggest size you can run. Might need a LVL or flitch beam if you want to make it taller. Pictures will help.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#10 |
AHH, SPANS!!!
you can reduce header width down by adding a structural header instead of a standard header. could gain a couple of inches at least, not a whole bunch of space. maybe 82 or 83" off of finished floor is all you need to clear the door and with 8' ceilings your opening is really close now...
#11 |
Moderator
Proscriptive built-up header spans, per code, use your local snow load: http://publicecodes.cyberregs.com/ic...002_par021.htm
Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| Tags |
door size, support beams, window replacement ![]() |
| Display Modes | |
| in ground pool bonding | vasben | Electrical | 18 | 07-14-2012 01:32 PM |
| Essex Potential Relay | Larry Huber | HVAC | 3 | 06-06-2012 11:39 AM |
| Potential Relay testing | dhubbard | Electrical | 1 | 09-15-2011 09:10 AM |
| testing a steveco 90-66 potential relay - the method? | shag_carpet | HVAC | 5 | 02-20-2010 03:46 PM |
| voltage potential around in-ground pool | logi98 | Electrical | 20 | 07-05-2009 09:08 PM |
