Deadbolt Suddenly Stopped Working - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 01:03 PM   #1
Deadbolt suddenly stopped working
Hello,
I just went to lock my deadbolt from the outside using the key and found that the key was just turning freely without locking the door. The lever on the inside continues to work fine to lock and unlock the door. I also tested it in the locked position and had the same result: key spins but does not unlock it. What can I do to fix this?
Thanks!
shortstack is offline   Reply With Quote
Old 02-15-2012, 01:11 PM   #2
DIY staff
Rewards Points: 7,174
Most likely the locking leaver broke off---if the lock was loose in the door it could have just popped out of the slot.
Remove the lock--two screws inside on the flipper cover---check and see what's broken--
Dead bolts are inexpensive---and can be re-keyed to match what you have---many stores that sell locks can re-key it for about $7.00---
Old 02-16-2012, 02:56 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,268
+1
Depending on the lock, you can remove the cylinder and swap it out in some cases as well.
Washer Suddenly Stopped sweaty Electrical 3 01-18-2012 10:26 PM
Kitchen light/ceiling fan has stopped working? glamgirrl Electrical 5 07-11-2011 08:31 PM
Receptacle stopped working lovetobuild Electrical 3 02-11-2011 10:05 AM
Outlets stopped working RammsteinNicCage Electrical 12 05-03-2009 09:47 PM
Deadbolt suddenly won't retract Squeeealer Carpentry 1 07-14-2005 08:20 PM
