Dead Bolt On Front Door Changed Color? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-12-2012, 05:43 PM   #1
Rewards Points: 18
Dead Bolt on Front Door Changed Color?
I am hoping that someone can shed some light on this issue. I bought matching handles and locks for our two front doors. Yesterday, I noticed that the deadbolt locks are both discolored. They started out as brushed or satin nickel but now they are very yellow almost brass looking. What can cause this and is there a way to restore the original color?
Thank you.
Faucetguy is offline   Reply With Quote
Old 08-12-2012, 05:47 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 850
Most manufacturers have finish warranties. Call the manufacturer first.
The yellowing may be the result of the clear coat that is applied to the hardware degrading in the UV light.
Old 08-12-2012, 05:53 PM   #3
kwikfishron's Avatar
Rewards Points: 84
Same brand, matched set???
That shouldn't happen, call there customer service department, hopefully they will replace them.
I've never seen that issue before.
kwikfishron is offline   Reply With Quote
Old 08-12-2012, 06:52 PM   #4
Rewards Points: 18
but now the issue becomes who is going to replace the dead bolts. I had someone install them for me. I don't want to pay for someone to do it. I could probably figure it out. I have replaced several door knobs inside the house.
Old 08-12-2012, 07:04 PM   #5
Rewards Points: 84
If you can replace a door knob then you can replace a deadbolt.
The procedure is exactly the same.
The Following User Says Thank You to kwikfishron For This Useful Post:
Windows on Wash (08-12-2012)
Old 08-12-2012, 09:07 PM   #6
Rewards Points: 12,802
All it takes is a phillips screw driver and about 5 min.
What brand are they?
Putting color onto white brick or textured walls (need color suggestions!) Eliana Interior Decorating 2 01-18-2012 08:27 PM
faceless or dead front gfci mistergett Electrical 5 09-08-2009 06:55 PM
Problems with dead bolt in new door jkrodger Remodeling 12 01-12-2009 11:14 AM
My dead bolt is broken kimigriffith General DIY Discussions 3 06-09-2008 01:02 AM
double cylinder dead bolt sleuth General DIY Discussions 1 04-06-2006 07:46 PM
