Cutting Steel Siding To Replace Windows - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-11-2013, 04:21 PM   #16
"You can do anything"-Mom
brockmiera's Avatar
Originally Posted by rossfingal View Post
Good ideas -
A "nibbler" distorts the siding too much -
If you can't afford a "dual-saw" -
try a "multi-tool" -
Whatever you use -
Prime the cut edges, of the siding with some type of primer -
"Rust-O-Leum"? (SP?)
Use good caulk - "Quad", "Solar-Seal" ...
No silicone.
rossfingal
I think your siding is "Alside".
Yeah I saw that picture and thought the same thing. When he said steel siding I was thinking 26ga or thicker. That stuff looks much thinner than that.
brockmiera is offline   Reply With Quote
Old 02-11-2013, 08:00 PM   #17
If the frames are in good condition, thereis a conversion kit available fom Andersen. It will replace th jamb liners and sash and make it into their tilt wash double hung. Very esy to install s well.
mknasa dad is offline   Reply With Quote
Old 02-12-2013, 06:26 AM   #18
why no silicone? I use that for about everything. what would be some examples of properly flashing these windows.
frank10 is offline   Reply With Quote
Old 02-13-2013, 11:19 AM   #19
Rewards Points: 14
For cutting, what about a Rockwell Versacut? Never used one for that purpose but I have the tool and it seems like that would work. Use with a metal cutting blade. You can adjust the depth of the blade to your needs. Google it.
Might be too cumbersome, but maybe just a regular circular saw with the blade installed backward or with a metal blade. It works good for cutting steel and aluminum soffit material.
Fins59 is offline   Reply With Quote
Old 02-14-2013, 06:27 AM   #20
have used a skilsaw for cutting this stuff and when the siding is on the house, it would be way to cumbersome. don't know about a versacut. will have to check it out. thanks
Old 02-14-2013, 10:48 AM   #21
Home Performance
HomeSealed's Avatar
Rewards Points: 712
We don't deal with steel too much, but we cut back siding with a skill saw on a regular basis (aluminum, wood, etc). A good cordless unit works great, especially up on a ladder.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 02-14-2013, 12:24 PM   #22
what kind of blade do you use in the cordless?
Old 02-14-2013, 06:11 PM   #23
Rewards Points: 2,238
You can cut back siding with whatever saw will work.
The only consideration with Steel Siding - most manufacturers consider the
warranty void if you use a saw -
Use a "shear", "power-snips", snips ...
Prime the cut edges with anti-rust paint - no matter what you use to cut.
rossfingal
rossfingal is offline   Reply With Quote
Replace just two windows - dumb idea? ChrisJJ Windows and Doors 13 06-01-2012 10:31 AM
copper "roof" to bay windows stained siding.. diy'er on LI Painting 10 04-24-2012 08:48 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Adding a window - cutting through Aluminum Siding -how to repair siding to look good? DyerWolf Building & Construction 6 12-22-2008 04:02 PM
Cutting asbestos siding Marvin Gardens Building & Construction 22 12-06-2008 05:00 PM
