Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 09-17-2011, 12:22 PM   #1
cutting inside window stop molding
Hello
I am replacing the missing window stop molding also called jamb extension. My question is what are the correct compound miter saw settings to make the molding fit together at the top? I have tried all different settings for crown molding, but nothing seems to work.
Help!
J
joes64 is offline   Reply With Quote
Old 09-17-2011, 12:39 PM   #2
Windows & Remodeling
HomeSealed's Avatar
A pic would definitely help here, as you might be a little bit confused on the proper terms. Most interior woodwork is mitered at 45 degrees strong, unless it is crown or something along those lines.
HomeSealed is offline   Reply With Quote
Old 09-17-2011, 02:13 PM   #3
Sorry! Here is a link to some pics:
http://tinyurl.com/3mjgprb
Old 09-18-2011, 08:30 PM   #4
HomeSealed's Avatar
Ok, those are inside stops, and they will be mitered at 45 degrees in the upper corners.
painting inside window citygirl Painting 6 02-13-2011 02:45 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
Help with replacing exterior window molding nugentoffer Carpentry 11 03-29-2010 06:58 AM
cutting cove molding Bluwolf Remodeling 2 09-11-2009 08:39 AM
Painting the inside edge of cutting board slots 1655graff Painting 8 01-28-2008 08:51 PM
