-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   cutting inside window stop molding (http://www.diychatroom.com/f104/cutting-inside-window-stop-molding-117504/)
joes64 09-17-2011 11:22 AM
Hello
I am replacing the missing window stop molding also called jamb extension. My question is what are the correct compound miter saw settings to make the molding fit together at the top? I have tried all different settings for crown molding, but nothing seems to work.
Help!
J
HomeSealed 09-17-2011 11:39 AM
A pic would definitely help here, as you might be a little bit confused on the proper terms. Most interior woodwork is mitered at 45 degrees strong, unless it is crown or something along those lines.
joes64 09-17-2011 01:13 PM
Sorry! Here is a link to some pics:
http://tinyurl.com/3mjgprb
HomeSealed 09-18-2011 07:30 PM
Ok, those are inside stops, and they will be mitered at 45 degrees in the upper corners.
