Cutting Block - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-06-2013, 07:17 PM   #1
Cutting block
Quick and easy questinon for the pros out there. What do you use to cut block foundation for installing an egress window? I used a quickie saw when I cut the slab to redo/rough in plumbing in the basement which worked very well and would be nice but that will only go 4.5" deep. Wonder if there is a miracle saw that will cut all the way through or if Im going to have to cut from both sides.
Leroy
lk00331 is offline   Reply With Quote
Old 05-06-2013, 08:17 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Concrete saw cut from both sides is the only way that I've ever done it... Try posting over in the masonry forum as well, maybe there is some special tool that those guys know about.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 05-06-2013, 08:18 PM   #3
Thx for the reply and will do.
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 08:03 AM
After cutting concrete block... TipsyMcStagger Building & Construction 8 12-01-2011 08:28 PM
Rebuilding a cinder block wall Pawl Building & Construction 5 10-09-2011 10:46 PM
Drywall over 4" block wall base JustADoc Drywall & Plaster 7 09-12-2011 11:47 PM
What to do with windows when firring out from a block wall. willemdejong Carpentry 1 06-04-2010 12:25 PM
