Customer is unhappy with how OSI Quad Caulk looks around their front door
Let it cure for a while, then scrape it off (it will still be pliable but not make as much of a mess). The remaining residue, streaks, etc can be cleaned with a solvent.
What did they find unacceptable about the appearance? Quad is a high grade caulk.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
