Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 09-24-2012, 12:52 AM   #1
custom height doors vs cutting
Hello,
I'm remodeling my basement and plan to replace all of the interior doors with molded 6-panels. Unfortunately none of the rough openings are standard height due to "creative" HVAC ducting and support beams. I cannot modify these ROs. I'm dealing with 76 1/2" RO height. I would have to trim around 6" from the bottom of the jamb and door to make a standard pre-hung 30"x80" door fit. Is that too much to chop off a molded door, even if it's the "solid" core version (e.g. Masonite SafeNSound)? I know I would also need to find doors without pre-drilled knob holes so they wouldn't be too low after cutting.
If I order "custom" sized doors, would the manufacturer be doing the exact same thing I'm doing and just replacing the bottom rail for integrity? I'm doubting they actually modify the mold and panel placement. If so, I'd rather just do the cuts myself and spare the custom cost. Any info is appreciated!
mefferz is offline   Reply With Quote
Old 09-24-2012, 06:49 AM   #2
Exterior Construction
Windows on Wash's Avatar
Custom sized door would likely trim material from both ends to center the door and hardware.
What is the bump for the custom size and they often have the next size down in RO and it doesn't mean that its custom, just not standard.
Replacing Doors in masonry wall mwpiper Project Showcase 17 05-12-2011 08:00 AM
my uneven floors are making my doors uneven fundaqueens Windows and Doors 4 05-04-2011 10:00 PM
Cutting Trim and Hanging Doors ws450r Carpentry 8 12-28-2010 03:54 AM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
