Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 04-03-2011, 07:53 PM   #1
custom door project
So I recently made a wall dividing two rooms, In a garage apartment that I play around with. It has an opening 34 1/4 inch wide and 81 inches tall. The wall is a box frame, covered with drywall. What I am planning to do is make a boxframe for the door, and use drywall to close it, so that it blends in with the wall when closed, and creates a "secret" room. More for fun then anything. I was wondering at how much clearance I should give for the hinges so that it can close pretty tightly, and maybe some ideas on a "handle" that blends in. Thanks in advance
purvisj2 is offline   Reply With Quote
Old 04-07-2011, 03:36 PM   #2
Tangelo's Avatar
custom door project
I think this is what your looking for, Soss Heavy Duty Concealed Hinges.
  • For 1-3/4" and 2" door thicknesses.
  • Hinge is completely concealed when door is closed.
  • Hinge opens a maximum of 180 degrees.
  • Made from high strength plated steel and heavy duty zinc alloy castings.
  • For full size doors.
  • Reinforced nylon at wear points for long life.
  • Matching screws are included.
  • Mortise depth 1-19/32"
[IMG]file:///C:/DOCUME%7E1/axd806/LOCALS%7E1/Temp/moz-screenshot-12.png[/IMG]
Tangelo is offline   Reply With Quote
Cabinets - Custom vs High Quality Prefab? FlyingHammer Remodeling 13 04-20-2011 04:08 PM
New custom house, concerns/problems. pretzels Building & Construction 15 04-16-2011 02:17 PM
Prefab or custom stairs? brokie General Discussion 1 01-21-2008 08:11 PM
