A Crack On The Glass Of A Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-11-2014, 08:58 AM   #1
Rewards Points: 1,046
a crack on the glass of a window
Hello
I just noticed this morning there was a crack on one of my windows !!!
Does that mean I have to replace the whole window, or it can be repaired?
Where should I go for this type of repair?
french_guy is offline   Reply With Quote
Old 01-11-2014, 11:32 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,798
You will have to replace that sash.
Contact the manufacturer first and see if stress cracks are a covered warranty item.
That is what you have.
Look for the manufacturer's label and serial number in the window head.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Tom Struble (01-19-2014)
Old 01-13-2014, 04:26 PM   #3
In a little over my head
Rewards Points: 706
I guess that's one loss due to technology. Now windows are warrantied, high tech, manufactured items (that work very well). Used to be, digging out the glazing compound, removing the points and old glass, replacing the glass and points and putty was a cool DIY project. I remember doing it with my Grandpa and my dad. Ahhh, the old days......
ratherbefishing is offline   Reply With Quote
The Following 4 Users Say Thank You to ratherbefishing For This Useful Post:
cyberknight (01-13-2014), gmaint (03-18-2014), Gymschu (01-13-2014), mt999999 (03-03-2014)
Old 01-19-2014, 09:48 AM   #4
What is the average warranty period on vinyl windows?
Old 01-19-2014, 11:45 AM   #5
Tom Struble's Avatar
Rewards Points: 2,002
there must be a glazing bead no?
Tom Struble is offline   Reply With Quote
Old 01-19-2014, 04:33 PM   #6
Rewards Points: 13,270
There is no "average" warranty. There all different. Better windows are life time warranty.
If there's several windows I would suspect a bad install job.
To tight and there going to crack.
Old 01-19-2014, 05:25 PM   #7
It's only one...and I hope it will be the only one !!!
Old 02-18-2014, 01:18 PM   #8
Rewards Points: 808
You mean the old days when you couldn't get anywhere near your windows in winter due to the incredible drafts? The old days when heating oil was .22 cents a gallon? The old days when homes were uninsulated?
IslandGuy is offline   Reply With Quote
Old 03-06-2014, 10:01 PM   #9
What is the window head? I've got a couple sashes with blown seals that I need to try finding the manufacturer for.
Sent from my Nexus 5 using Tapatalk
atlgator is offline   Reply With Quote
Old 03-18-2014, 07:43 AM   #10
Window head jamb is where the upper sash shuts into the frame.
Old 03-21-2014, 09:59 AM   #11
You don't need to replace the whole window, only the glass. Contact the manufacturer or vendor company, from which you purchased the product.
Jonathon C. is offline   Reply With Quote
Help with a Window Removal/Install anthony232 Windows and Doors 12 09-18-2013 05:39 PM
Bay Window Glass & Crank Repair? miamicuse Windows and Doors 5 04-27-2013 09:06 AM
Double-hung window sash glass replacement teetee1 Windows and Doors 1 03-10-2012 12:21 PM
Need Advice For Fun Project - liberating stained glass window jackson33 Building & Construction 9 03-08-2011 05:09 PM
