Costing Alside Vinyl Replacements - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 06:50 PM   #1
839038 TOP SASH 0501 LOCKS: 1 I FACTORY MULLED
GLASS: 15 3/8 X 20 7/16 COLR' WHT-BRONZE Grid: While
DESC : CONTOUR COLONIAL 1Ux0HC - DLOE SCRN: FULL-FIBERGLASS Transfer lo Kinston
SASH : 17 1/4 X 22 5/18 REIN: 10 0
1111111111111111111111111111111111111
F-R7824 0216UMMl W-146 P-3518
._1· DUE 02/22/12 FO QTY: 8
Can anyone tell me how I can find out what this particular replacement window should cost. I am referring only to the cost of the window and not including installation.
Thanks for the help
saw
saw46 is offline   Reply With Quote
Old 05-28-2012, 07:57 PM   #2
Rewards Points: 13,690
Call Alside tomorrow and ask them. How would anyone here know?
Old 05-29-2012, 10:32 AM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
The actual cost of the window is going to vary greatly across the board. The cost for one of their high-volume dealers is going to be different from a low-volume dealer, and different still from someone walking in off the street.
Those numbers mean nothing to anybody that doesn't work at the factory, but if you want a range, as a consumer you'll probably pay somewhere between $150 and $350 for one of their more common units.
If you are in need of service on that window, as Joe said, just call them directly if your original dealer is not around.
Edit: After looking again, I see that it has a bronze exterior. Expect the price to be on the high end of that range or even more.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Atrium vinyl replacements don30068 Windows and Doors 5 05-22-2012 03:45 PM
framing for vinyl wind barrier (See photos) Carolyn252 Building & Construction 2 09-02-2011 04:50 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
