Cost To Repair Home Windows? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-08-2013, 08:48 AM   #1
cost to repair home windows?
I have 5-6 windows in my house which need to be fixed - the glass is fine, but the ropes and weights should be fixed - I don't want the actually windows replaced, just fixed. I have no idea of where to start, or how much it should cost. Any thoughts?
TTpainting is offline   Reply With Quote
Old 10-08-2013, 09:10 AM   #2
Rewards Points: 12,858
Why not just do it yourself, then the only cost is some sash cord.
You do know by keeping windows that old it's costing you a ton of money in added heating and cooling cost, right.
Old 10-08-2013, 09:11 AM   #3
PoleCat's Avatar
Rewards Points: 1,646
There is an access panel toward the bottom of the track that you remove to service the counter weights. Once you get it open it is pretty easy to replace the cord.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 10-08-2013, 10:40 AM   #4
Rewards Points: 5,974
Not necessarily Joe up there they usually use storm windows which create an air space between the glass.
Old 10-08-2013, 03:16 PM   #5
Oso954's Avatar
Rewards Points: 438
Storm Windows don't do anything for cold infiltration thru the sash weight pockets. It can be more than just the uninsulated space. Often you get a cold draft thru the pocket.
There are several sash weight elimination kits out there that eliminate the need for the pocket, allowing you to insulate it. I would talk to a local window company about them.
Oso954 is offline   Reply With Quote
Improper drainage around my home? Suggestions and cost estimates daluu Landscaping & Lawn Care 3 01-15-2013 11:10 AM
Sunroom extension support footings repair + cost gentlemansbeard Building & Construction 11 03-25-2011 03:40 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 04:47 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 08:27 AM
