cost to install a new window
This may be a silly question given that this is a DIY site, but are you asking for the price a a window alone that you will then install?... Or the price for an "installed" window in those conditions?
A decent window will be a minimum of about $200 (could be much higher depending on options, material, etc). Installed, the project that you are describing is a bit more "advanced" given the cut-in into block. Could go anywhere from the $1-$2k range or higher depending on additional details.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
