Cost To Enlarge An Interior Door From 30" Opening To 36" - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-05-2013, 12:27 PM   #1
Cost to enlarge an interior door from 30" opening to 36"
My garage door is only 30" wide and I want to enlarge it to 36" wide. I have paneling on one side ( which will be gone in few months and replaced with sheetrock so inside doesn't need to be repaired just covered up w/ old paneling) and sheetrock on the other side. I have one electrical light switch that will need to be relocated.
I will buy the door & frame.
What would a fair cost be for labor?
I have a never ending list of home improvements in my future. This is at the top of the list. I have large furniture to move around and instead of walking out the back of the house around the front to the garage I really want to make life easy. Thanks
hibob is offline   Reply With Quote
Old 09-05-2013, 01:45 PM   #2
kwikfishron's Avatar
Rewards Points: 86
Nobody can really answer that here, labor cost can vary greatly from one area to the next. Your best bet is to get a few local bids.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
oh'mike (09-05-2013), woodworkbykirk (09-06-2013)
Old 09-05-2013, 03:45 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 818
Chances are the cost of install will be more than the door.
I would contact a couple of door and window businesses and get a quote.
You can get the same thing at HD...but typically they just farm it out to a list of contractors they use.
Old 09-05-2013, 06:43 PM   #4
Framing Contractor
Rewards Points: 98
This will probably take one competent carpenter a full day to accomplish. The framed header will need to be enlarged, meaning a temporary support wall might be needed. Remove old door, install new door and hardware. Any finish carpentry/drywall/paint will make it take longer. If you know what hourly rates local carpenters charge, this will probably give you a general idea.
sixeightten is offline   Reply With Quote
The Following 3 Users Say Thank You to sixeightten For This Useful Post:
kwikfishron (09-05-2013), oh'mike (09-05-2013), woodworkbykirk (09-06-2013)
Old 09-06-2013, 09:56 AM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Best idea is to get a couple quotes. Just too many variables to give accurate pricing.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
40" opening (2x) 24" bifold doors too wide 36" too small DIY-HomeGuy Remodeling 6 06-09-2012 10:55 AM
framing a 30" cased opening with no door (a walkthru) chrisjohns Carpentry 4 04-12-2010 06:48 PM
