Converging Pocket Doors. - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-12-2014, 04:16 PM   #1
Rewards Points: 99
converging pocket doors.
I'm looking to install converging pocket doors leading in to a laundry room in a new addition. i've been reading up on how these go in, and they require an open space of 4X the door width. unfortunately its a bearing wall and I can't do this span, so my idea was to build a second 2X4 wall against the bearing wall, use that for the doors, have a conventional jam in the bearing wall, with the pocket doors behind it. so basically an 8" jam with the doors in the rear half. does this make sense? has anyone tried something similar or have better advice? and finally, any reco on the best kits? I see a lot of Johnson in my searches.
thx!
yellowkid is offline   Reply With Quote
Old 05-12-2014, 04:47 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 780
I don't see why it wouldn't work. I can't help you on the hardware.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 05-12-2014, 05:36 PM   #3
Rob
Robpo's Avatar
Rewards Points: 826
I would build the second wall on the flat(1 1/2 thick instead of 3 1/2). Not sure that is what you meant. I would think about notching the existing wall where the door goes and adding more 2xs on flat.
Robpo is offline   Reply With Quote
Old 05-12-2014, 05:41 PM   #4
Rewards Points: 14,306
Adding a proper header would allow you to do it.
kwikfishron (05-12-2014)
Old 05-12-2014, 06:22 PM   #5
Rewards Points: 256
thx!
are you sure you don't mean 2x the door width ?
oldrivers is offline   Reply With Quote
The Following User Says Thank You to oldrivers For This Useful Post:
MTN REMODEL LLC (05-12-2014)
Old 05-12-2014, 10:35 PM   #6
That is the best way to do it. A lot of people use the pre-built pocket door frames and they are junk. Build the pockets out of 2x4 on each side and you will not get the wall wobble effect when you push on it.
Johnson hardware is good. I use it often.
uncommon doors is offline   Reply With Quote
Old 05-13-2014, 12:16 AM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 780
That would be for a single pocket door, a double pocket door would need 4X.
Jim
Old 05-13-2014, 07:26 AM   #8
I used that approach with my master bath remodel. But the circumstances were different. My existing wall had electrical in it. So to avoid messing with the wiring, I built a new wall/compartment in front of the existing opening to house my (single) pocket door. It worked beautifully! The only sacrifice was that we lost about 5 1/2" by 56 1/2"of space from the bedroom. It was well worth it. You've got the right idea. Build the compartment yourself. The ones sold in the stores are incredibly flimsy. I would recommend using Johnson Hardware's heavy duty track if possible. Good luck!
DIYRemodeler is offline   Reply With Quote
Old 05-13-2014, 08:38 AM   #9
Rewards Points: 99
thx!
excellent thx to all for your comments. always nice to hear your on the right track!
Pocket doors emra21 Windows and Doors 12 01-16-2012 06:36 PM
non pocket sliding doors? jamesdart Remodeling 3 03-07-2009 04:48 PM
Pocket doors ? burita General DIY Discussions 2 01-08-2006 09:38 PM
Pocket Doors wicklowdesigns@yahoo.com Building & Construction 2 07-06-2005 07:21 AM
