Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 01-22-2013, 02:34 PM   #1
Condensation on Windows inside
My two basement windows are having condensation on the inside of the house where I have to wipe it everytime. The basement is finished and there are a heat vent within a couple of feet from the windows. They are in two separate rooms. The room's humidity is around 25%. These window are usually closed off with wooden blind doors as seen in one pic on located onthe side of the windows. No other windows in the house does this. These windows are about 18 years old. I have to since turned off the house's humidifier with no luck. It is about 15-25 degrees outside while indoor temp is about 78-80. Are these windows comprismised? What can I do??
Condensation on Windows inside-win1.jpg   Condensation on Windows inside-win2.jpg   Condensation on Windows inside-win3.jpg
need2speed75 is offline   Reply With Quote
Old 01-22-2013, 03:28 PM   #2
Holy crap, you keep your indoor temps at 78-80 degrees?
Anyway, I don't know what you mean by "comprismised", but installing storm windows will probably resolve that. You can get either interior or exterior storm windows, since it looks like you don't open that window anyway, it should be easy installing something to use as a storm window (you could even make your own out of Plexiglas).
As a quick fix, you could just put some of that plastic window film on the inside, you can find it in any hardware store or home center.
wrongdave is offline   Reply With Quote
Old 01-22-2013, 03:28 PM   #3
Windows & Remodeling
HomeSealed's Avatar
78-80*? Why do you have it so hot in there?
Is that single pane glass? If so, at those outside temps you are going to need it to be drier than a bone inside to keep condensation from occurring. Keeping those shutters closed will only make it worse as well.
HomeSealed is offline   Reply With Quote
Old 01-22-2013, 03:32 PM   #4
Best way would be to get rid of those old windows.
Second best is to not block them off like that so the air can move and dry them out.
HomeSealed (01-22-2013)
Old 01-22-2013, 10:06 PM   #5
Windows & Dogs
Taylor Rae's Avatar
I have to agree, I don't think there's much you can do if they are single pane. Also, it also means that you are losing a lot of your costly heat through those windows so It might be worth taking a look at replacing them at this point.
Taylor Rae is offline   Reply With Quote
Old 01-23-2013, 12:47 AM   #6
747
registered
747's Avatar
Open your yellow pages under glass companys. Stop by one and ask how much would you charge me installed two replacement windows. I'm thinking 500,
747 is offline   Reply With Quote
Old 01-23-2013, 11:23 AM   #7
Newbie Bill
Good advice from everyone. Start with the cheaper solutions first.
- Keep the shutters open so air can circulate to see if that helps.
- Pick up some of that plastic window film. It will help but is a bit of a pain.
- Storm windows? In my opinion, if you are going to the trouble of obtaining storm windows, just have these ones replaced.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 01-23-2013, 12:05 PM   #8
HomeSealed's Avatar
The problem with interior storms is that they will allow that moisture to migrate past, so the existing windows (and wood frames) are going to be covered in water/ice. If you want to go with storms, exterior would be advisable... That said, I still think window replacement might be your best bet based on the pics. If those units are only 18 yrs old, they have lived a pretty hard life.
If you have 0 budget to improve the situation, then as mentioned above, try improving the circulation there first, and if that doesn't help, the interior could be sealed with plastic.
The Following User Says Thank You to HomeSealed For This Useful Post:
drtbk4ever (01-23-2013)
Old 01-31-2013, 10:16 AM   #9
replace the windows , these windows have exceded thier life
glass block with a vent for basement windows are best for this applacation
1vinylexteriors is offline   Reply With Quote
Replace just two windows - dumb idea? ChrisJJ Windows and Doors 13 06-01-2012 11:31 AM
Condensation on new vinyl windows jimleahman Windows and Doors 12 02-22-2012 02:17 PM
Moisture inside large windows mibson Building & Construction 5 02-13-2011 02:25 PM
Replacing windows from the inside RosenKen Remodeling 3 08-06-2009 01:27 PM
Condensation on New Windows javan General Discussion 4 11-04-2008 08:21 AM
