Condensation On Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-20-2011, 10:48 AM   #1
Condensation on windows
Every morning when I get up the windows have condensation on the outside...so much so that I can't see out them! The AC is on inside at 20 degrees Celsius... And most of the windows are vinyl... Is this ok? Is there anything I should do?
stoked91 is offline   Reply With Quote
Old 07-20-2011, 05:17 PM   #2
Rewards Points: 2,638
20 Degrees C ?
I don't think I could stand it that cold.
Do your electricity bill a favour and turn up your thermostat a little. Should help with the condensation, too.
SPS-1 is offline   Reply With Quote
Old 07-20-2011, 05:28 PM   #3
concretemasonry's Avatar
Rewards Points: 2,626
The glass is cooler than the dew point outside, causing the condensation on the outside.
Many people make the mistake of thinking the multi-layer, gas filled windows really insulate. - The U value is about the same or not much better than an uninsulated 8" concrete block without the benfits of thermal mass and zero radiant heat transmission.
They are still better than hole in the wall.
Turn up your thermostat. We have ours at 75F 24/7 and still get some condensation. Yesterday, with 96F and 85% humidity, we had condensation all day on the lower level because of the proximity to the grass/soil after a morning 2" rain shower in 15 minutes.
Dick
concretemasonry is online now   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
MJW (07-20-2011)
Old 07-20-2011, 05:50 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
What Dick said
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Extreme condensation on single pane windows ikessky General DIY Discussions 2 01-24-2011 02:31 PM
Condensation on outside of windows between window and screens Kelcala Building & Construction 2 08-13-2010 07:59 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
aluminum windows condensation smalan Building & Construction 2 01-02-2009 07:51 PM
